This plugin allows to insert bundler with selected data into cluster or object wire.
Cluster:
After:
Object:
After:
Notes:
Plugin LLB is saved in LabVIEW 2015.
EDIT:
2018-04-09: [DNatt] Added Request Deallocation function call to plugin diagram.
2016-07-12: Nested cluster All Elements fix
2016-07-05: Optimized (more stable, faster) version updated.
I really like it - it saves my time!
Thank you Arek, appreciate ![]()
Tried with a cluster2 inside a cluster1. In that case, choosing the Insert All Elements of cluster2, does not insert what it is supposed to insert: Cluster2, but a sub-element of Cluster2.
Apart from that quirk - great tool
Heel, thank you for your feedback. You are right. There was a All Elements bug, but it is fixed now.
Great to hear you like it.
Best!
great - now it works nicely. looking forward to use - I like to use a lot of clusters.
didn't you know about quick drop?faster than the tools
@Suda苏打! Many users know of QuickDrop but there are only so many keyboard shortcuts most people can remember. For a lot of folks, they need to fall back on menus.
I did want to add some sort of convention to the naming of menu items to show the related QD shortcut key if there was one, so that people could discover the link between a given menu item and QD over time (similar to how the shortcut keys are listed in drop menus). But that kind of notation is explicitly discouraged by OS standards on both Mac and Windows. I don't know the details of why, but usually when Apple and Microsoft both agree on a given UI standard, it's got a lot of research behind it to justify it, so I haven't taken that route with the ones I've written. A given plug-in author could, of course, add a shortcut notation for their plug-in.
you can check this@AristosQueue
@Suda苏打! I get an "access denied" message trying to visit that page.
 AristosQueue  ,not lucky.
Very cool plugin, but unfortunately, from time to time it causes LabVIEW to hand, and crash... Pity...
Thanks a lot, Darren!
Would be nice to update then files for download...
