LabVIEW Interface for Arduino Discussions
write and read to arduino at the same time
Hi there people
I have this lab project where I control a servo through LabVIEW 2010 and arduino UNO REV3. The thing is to sample values from arduino' s analog input 0 (I have connected a photodiode), every 5 degrees of servo's position and make a table of sampled values vs degrees.
I know  there are two VI arduino examples in LabVIEW: Arduino Servo VI and Arduino Photocell VI (which I tried separately) but I can' t combine these two together. Please help me.
(5,252 Views)
TomPap,
I recommend looking into the State Machine Architecture and Producer Consumer Architecture.
Post some code and we'll see if we can point you in the right direction.
-Sam K
(3,421 Views)
Accepted by TomPap
It sounds to me like you might just be trying to initiate Arduino twice.  To write an angle an then immediately read a value from the photocell you need to do something like this:
If you need special timing to make sure that the servo has finished moving then you would want to use one of the options given by Sam.
(3,421 Views)
