LabVIEW Interface for Arduino Discussions
how to enable 2 or more analog input pin in arduino uno labview simultaneously for voltage analysis?
Hi Sammy_K,
I have tried your suggestions using the ReadPort vi but i'm still getting mixed voltage readings from 2 sensors in my circuit. For simplicity I have used a code similar to what mknix has posted above. Thanks!
Message 11 of 15
(2,128 Views)
If by "mixed voltage" you mean crosstalk (the signal from one line showing up on another), then you probably need to do some sort of sheilding for each of the sensor lines.  At least this is the suggestion that I got when I had this issue with an sbRIO.
Message 12 of 15
(2,128 Views)
I agree with Nathan_B. I would suggest you to double check your electronics and common ground connection. Try using a multi-meter to check input voltages. Good luck.
Message 13 of 15
(2,128 Views)
what does this error mean?
Message 14 of 15
(2,128 Views)
Hey mortenx,
You should create a new thread if your question is not related to the topic being discussed in this thread.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
Message 15 of 15
(2,128 Views)
