‎11-22-2013 12:38 AM
Hi Sammy_K,
I have tried your suggestions using the ReadPort vi but i'm still getting mixed voltage readings from 2 sensors in my circuit. For simplicity I have used a code similar to what mknix has posted above. Thanks!
‎11-22-2013 02:05 AM
If by "mixed voltage" you mean crosstalk (the signal from one line showing up on another), then you probably need to do some sort of sheilding for each of the sensor lines. At least this is the suggestion that I got when I had this issue with an sbRIO.
‎11-22-2013 12:41 PM
I agree with Nathan_B. I would suggest you to double check your electronics and common ground connection. Try using a multi-meter to check input voltages. Good luck.
‎03-06-2014 09:05 AM
what does this error mean?
‎03-07-2014 01:10 PM
Hey mortenx,
You should create a new thread if your question is not related to the topic being discussed in this thread.
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
