01-03-2014 03:32 PM
You should create a new discussion because this particular one is not related to your issue.
02-23-2014 07:08 AM
hey,
i m trying to interface arduino uno and labview....
i developed the block diagram... the baud rate i m using is (38400)... i m trying to read a register of cc1101 that has 1 byte value (for example 0x74)...
i m using SPI mode 0 and clock dividor of 4....
i get an error "
Error 5005 occurred at Unable to find Arduino. Please make sure the Arduino is connected to your system and that the Arduino drivers are installed."
my arduino is being detected successfully.... i ve drivers updated.... cant figure out the issue....... can any 1 help plxxx?
11-09-2014 03:30 PM
alguein me podria ayudar con la coneccion de arduino DUE con labview, no consigo hacer la coneccion con esta libreria
11-09-2014 05:57 PM
When LIFA first came out the Arduino IDE used a .pde extension for sketches. But a couple of years ago the Arduino IDE started using .ino extension for sketches. Hence you should be looking for LIFA_Base.ino.
hrh212
11-09-2014 06:39 PM
no, esa etencion tampoco es compatible con mi tarjeta arduino DUE, por eso he tenido complicaciones al realizar la coneion con labview
11-09-2014 06:59 PM
An Arduino Due is not compatible with LIFA or LINX.
hrh212
11-09-2014 07:02 PM
entonces con cual es compatible? o como se realiza la comunicacion?
11-09-2014 08:31 PM
LIFA is compatible with the Arduino Uno and the Mega 2560.
LINX is compatible with the Arduino Uno, Mega 2560, Leonardo, Nano and Mega 1280.
hr212
03-03-2016 12:54 PM
thanks for lvifa link, i had the same problem but after downloading the zip it worked..though it still giving me error 5002 and don't know whats the problem
