LabVIEW Interface for Arduino Discussions
Where is LVIFA_Base.pde for LabView 2012
As an update:  I just went through the above process on a WIN7 computer with LV 2011SP1.  After finding out about the .pde to .ino file change it worked like a charm.  Thanks.
Message 21 of 39
(2,668 Views)
do we have seprate lifa base file for arduino uno and arduino mega?
if yes then please attach the link  please.
Message 22 of 39
(2,668 Views)
The Uno and the Mega use the same firmware.  There is code in it to account for the differences automatically.
Message 23 of 39
(2,668 Views)
i'm attaching link for downloading LVIFA Base.pde for LabVIEW 2012
https://drive.google.com/folderview?id=0B583mduU6WwaSEtKMlVySGJGb0E&usp=sharing
Message 24 of 39
(2,668 Views)
The firmware comes with LIFA and should be obtained via the JKI Package Manager.
Message 25 of 39
(2,668 Views)
how to dump lifa_base.pde to arduino i am getting error
Message 26 of 39
(2,668 Views)
i am getting error of synclv is not declared in this scopeplz find error n send me original pde file
Message 27 of 39
(2,668 Views)
The correct files come with LIFA and are in the Firmware folder.  If you are getting errors about things not being in scope that usually means that the Arduino IDE is not opening all the files.  Make sure that you first start the Arduino IDE and then select File > Open and select LIFA_Base.ino.  It will then open all files in that folder.  You should be able to compile it then.
Message 28 of 39
(2,668 Views)
thanks you very much from .....
Message 29 of 39
(2,668 Views)
Good morning I have a problem now that I can not do my Arduino DUE now communicate with their poles above him and managed to install the program on the Arduino board. Now I can only communication from RX to TX Transmit is not working, can anyone help me?
Message 30 of 39
(2,668 Views)
