LabVIEW Interface for Arduino Discussions
Using labview arduino in mac?
Update.. I was succed with that..
thank you I miss one step, I must donload a file to arduino board.
Now I want to ask are the data can become ascii format?
daniel
Message 11 of 14
(1,112 Views)
Hello Daniel,
For all of the Arduino examples that come with Labview you must use the Labview Interface for Arduino firmware you installed during step 6 of the set up procedure.  So yes you are programming your Arduino Uno with the Labview Interface for Arduino firmware.    Extensions to the examples like reading from multiple analog pins also use the same Labview Interface for Arduino firmware.
hrh1818
Message 12 of 14
(1,112 Views)
Hello Daniel,
Yes you can convert the data to ASCII format.  See Functions Palette > Programming > String > String/Number Conversions.
hrh1818
Message 13 of 14
(1,112 Views)
Thank you a lot.. you help me
regard
daniel
Message 14 of 14
(1,112 Views)
