LabVIEW Interface for Arduino Discussions
PWM and DC Brushless
Hi all,
I wanted to create a pwm signal from my arduino mega 2560 to my DC brushless by using the attached code but something goes wrong, I kept getting error message from labview.
Please help me if anyone knows the solution.
Thank you!
Loo
(4,841 Views)
I claim you need two "digital write" sub vis in your block diagram.  One "digtal write" to write the pin direction information.  A second "digital write" to wtrite the PWM siganl to the pin .  Try this modification and let us know if it works.
hrh1818
(3,766 Views)
What error messages are you getting?  What are you using for a motor controller?
Tip:  Never use the "Set Digital Pin Mode.vi" inside of a repeating loop (unless you are changing the mode mid-execution), it will just slow down the Arduino.  Put it outside of the loop after "Init.vi".
(3,767 Views)
My comment about needing two digital write sub VIs is bad advice.  I need a lot more time to come up with a better solution  Most llkely others will beat me to a solution.
hrh1818
(3,767 Views)
Attached is a version of your PWM that works.   Two comments:
One.  In this version Run the VI, Enter a PWM value and then click on Send.  Repeat the Enter a PWM value and Send sequence as manry times as required.  Click on Stop to quit.
Two.  This version was modifeid to work with COM port 3 on my computer.  You may  need to change the COM port to work with your computer.
hrh1818
(3,767 Views)
thanks guys for your suggestions.
I am using ESP for the speed control
everything is ok when I put "Set digital pin mode" outside the loop!
Cheers,
Loo
(3,767 Views)
