LabVIEW Interface for Arduino Discussions
MPU6050+Arduino+Labview
gracias amigo me salvaste la vida
Message 11 of 35
(5,952 Views)
Hi Nathan
I am using LSM6DS0 (Accelerometer+Gyroscope) in my project. I was wondering if you know any library for this sensor.(LIFA file)
Message 12 of 35
(5,952 Views)
There does not exist a library for that sensor. If you can't find something
in the LIFA documents or discussions then it probably doesn't exist.
Message 13 of 35
(5,952 Views)
Thanks for the reply,
Do you have any source documents so I can create my own .h & .cpp file for this sensor.
I would need to read data from accelerometer and gyroscope using Arduino Uno interfacing with LabVIEW.
Thanks.
Message 14 of 35
(5,952 Views)
If you want to use LIFA and the sensor uses I2C then you wouldn't need to
create any C code and could do all basic functionality in LabVIEW. You can
take a look at the MPU-6050 code from the library that I created in the
documents section.
Message 15 of 35
(5,952 Views)
Hey Nathan,
I was not able to find the document for the library of MPU-6050.
Could you please post it again here.
Thanks.
Message 16 of 35
(5,952 Views)
https://decibel.ni.com/content/docs/DOC-34263
Message 17 of 35
(5,952 Views)
Thanks Nathan
But, this is just the labview file, I did not find any sketch folder.
Message 18 of 35
(5,952 Views)
Like I said, I doesn't require any C code. It works with LIFA
Message 19 of 35
(5,952 Views)
I guess, I don't have the LIFA, so I would need to do c code for getting data from my Arduino.
Message 20 of 35
(5,952 Views)
