‎04-03-2014 11:21 PM
Hi Mehr,
True! all sensors must be calibrated (to the accuracy one expects)
One ''issue" that discussed less often!! is that the accuracy which an Arduino board provides.
Then the overall accuracy of the system, Arduino and (in this example) the sensor you use.
Good luck with your project.
Barddya
‎03-31-2015 08:32 AM
Thank you very much.
Your code helped me a lot, I just made a few changes, like insert a chart to see the variation of the pressure and temperature values in time, instead of a 'textbox'.
‎08-02-2015 03:29 AM
Hey Nathan_B
I am having some troubles with my bmp085 sensor it does not display logical pressure readings resulting non-logical Altitude readings.it always swings between values & Does not give an accurate reading.
