LabVIEW Interface for Arduino Discussions
Barometric Pressure Sensor - BMP085
Hi Mehr,
True! all sensors must be calibrated (to the accuracy one expects)
One ''issue" that discussed less often!! is that the accuracy which an Arduino board provides.
Then the overall accuracy of the system, Arduino and (in this example) the sensor you use.
Good luck with your project.
Barddya
Message 51 of 53
(1,204 Views)
Thank you very much.
Your code helped me a lot, I just made a few changes, like insert a chart to see the variation of the pressure and temperature values in time, instead of a 'textbox'.
Message 52 of 53
(1,204 Views)
Hey Nathan_B
I am having some troubles with my bmp085 sensor it does not display logical pressure readings resulting non-logical Altitude readings.it always swings between values & Does not give an accurate reading.
Message 53 of 53
(1,204 Views)
