12-03-2012 09:02 AM
Thanks egaruz89
I will try to do this with pdf, don't worry about spanish we are to close, I am Portuguese.
best regards
cpalha
12-19-2012 01:34 AM
Hi RobWal, could you please post how do you get conect the file LABVIEWInterface.pde that was provided by egaruz89 with the library?
Best regards.
Screw
Pd. Sorry for my english, I am from mexico.
01-20-2013 03:47 AM
hey guys.
i am getting an error while uploading "output" was not declared in the scope
01-20-2013 01:07 PM
You'll need to make sure that you are running the same version of LIFA and Arduino IDE that was being used when the custom firmware was written to make sure that it will compile and work correctly. Hopefully that is the only thing that is causing issues.
05-11-2013 05:55 PM
How can I see the distance, the Indicator Array dont show me nothing :S
06-09-2013 01:06 AM
HI
When I was use to http://dl.dropbox.com/u/8067369/LabVIEWInterface.pde
apear this error
" LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)':
LabVIEWInterface:109: error: 'Ultrasonic' was not declared in this scope
LabVIEWInterface:109: error: expected `;' before 'ultrasonic'
LabVIEWInterface:531: error: 'ultrasonic' was not declared in this scope
LabVIEWInterface:531: error: 'CM' was not declared in this scope "
I was use to this "ultrasonic.h"
http://trollmaker.com/article3/arduino-and-hc-sr04-ultrasonic-sensor
what can I do???
the error "531" is this
"Serial.write( (ultrasonic.Ranging(CM)) ); "
06-09-2013 01:42 AM
First, you cannot put that code there. To use it with LIFA, you have to create a case for it in the switch and then create LabVIEW VIs to access the function on the Arduino.
Now to your question, in my experience those errors mean that the Arduino IDE is unable to find the .h file. Generally, when I add non-standard libraries to Arduino I put them in the LIFA_Base folder. If you are still getting "not declared" errors, you will want to make sure that the .h file gets opened with all the other files (it will be another tab).
Also, I don't see any library at the link that you posted. I just see a basic implementation of the sensor.
06-09-2013 02:06 AM
HI
I modify some thinks, and the error was diferent this time:
LabVIEWInterface.ino:109:1: error: unterminated #ifdef
LabVIEWInterface:531: error: 'ultrasonic' was not declared in this scope "
and mark this paragraph " Serial.write( (ultrasonic.Ranging()) );"
how can I implementation a library?
I only follow the steps of people
Sorry I can´t programer of "C" , I only can use Labview
What can I do?
06-12-2013 11:29 PM
HI,
i have a question
which "ultrasonic.h" did you use, I try with diferent kind and the http://dl.dropbox.com/u/8067369/LabVIEWInterface.pde
Show me error of compilation
thanks
06-20-2013 03:19 PM
you need to download the library "ultrasonic.h" for arduino, you can download on this page https://github.com/elrodri/Ultrasonic-HC-SR04, just add this library to arduino software and you can load the LabVIEWInterface.pde without problems, other thing that you have to do is, just have Arduino softeare open when you load the Lifabase
