User | Kudos |
5 | |
3 | |
3 | |
1 | |
1 |
Problem
Using the "Disconnect This Terminal" and "This Connection Is >> Required/Recommended/Optional" menu items can be tedious due to it being too easy to right-click on a different terminal than intended. This is especially true in VIs whose connector pane is densely populated with many inputs and outputs, or VIs that use one of the connector pane patterns that have more terminals than the standard 4-2-2-4.
To check that I applied the change to the terminal I intended, I often press Ctrl+S and Ctrl+H to quickly bring up Context Help and check that the terminal is indeed required, recommended or optional.
It would be useful if the two menu items would also be available in the shortcut menu that pops up when right-clicking the control or indicator in question, as shown in the screenshots below.
Notes
