ouadji
"Build Path" should be growable
Status: New
                                            "Build Path" should be Growable
                              something like this,
undefined
10 Comments
ouadji
Trusted Enthusiast
Here is another interesting  one , but mine is different.
My idea relates more specifically to the growable capability.
maybe combine both ?
AristosQueue (NI)
NI Employee (retired)
If this did get implemented, the trailing slashes in your picture would not be needed, just like they aren't today in Build Path.
ouadji
Trusted Enthusiast
@AristosQueue : "If this did get implemented, the trailing slashes in your picture would not be needed, just like they aren't today in Build Path."
indeed, You're right !
Knight of NI
To expand on this idea: BuildPath should accept an array of strings (or paths) too…
tst
Knight of NI Knight of NI
Knight of NI
It should probably be pointed out that LV already has a primitive called Array of Strings to Path, which does cover the basic functionality of this idea, although not with the same syntax.
___________________
Try to take over the world!
PhillipBrooks
If implemented, the companion Strip Path function should also allow be "growable".
Rob_F1
I like it, this wold be very useful and clean.
JÞB
Knight of NI
I like it!  like autoindexing a path to string array both ways!  We have the ability to code the stuff nativily but, this is one where NI R&D might be able to add more "bullet-proofness" than the general population.
"Should be" isn't "Is" -Jay
GregSands
With some other changes to Build Path now "In Beta", any thought of progressing this idea as well? It would make sense to implement a growable node for both Build Path and Strip Path.
AristosQueue (NI)
@GregSands No. It actually did come up in discussion this round, but, ultimately, we decided we had other priorities.
