User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
when you place some control in the front panel, You don't have any idea of his position, You don't have posibility to control de exact position of this control, and You can't edit this position, only you have a small tip strip display when you move this control.You cant change the position of a control wiht the properties nodes in execution time, but this is not enough.
solution:
place a display in the front panel, to display the absolute position of a control, and his size, and when it is selected, to able to put his position, in additional way in the properties of control, having the posibility to do the same operation.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Visualize-the-absolute-cordinates-when-moving-a-contr...
