User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
It'd be quite helpful if VI's could be set the Front panel position attribute.
For the 114th time, i just searched for something, scanned through the results and after a small fix compiled the program and deployed it. 2 Popup Panels dont work since they've moved and now show the input cluster ...
Either all Panels should be set to pos 0,0 at runtime, or be configurable as a run time pos.
/Y
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
