User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
The function Index & Bundle Cluster Array can be quite useful and mimics a bundle in a for loop.
The reverse operation (= unbundle in a for loop!) would be equally useful.
I wonder why it is not part of LabVIEW. Seems like an omission. 😉
I suggest to add it with the same icon graphics, but with left and right halves swapped.
(See also this example)
Even though this Idea has a relatively high number of kudos, LabVIEW R&D is currently declining to add new language elements unless they have a very compelling advantage. In this case, the desired output can be coded with existing constructs without too much difficulty.
