User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Now all VI properties from VI Properties: Window appearance are applied immediately to the VI. In some cases it could lead to unwanted behaviours.
If for example in development mode we open the VI which properties are set: user cannot close window along with the flag window is modal set to on, only one way to continue is to kill the whole LV environment from the task manager. In this case it equals to lost all unsaved work.
It would be good if the VI Window appearance properties which are highlighted below, were applied when VI works with RTE engine but NOT when is the VI is open under development mode. Of course they have to be editable under the development mode, but when the VI is running in development mode LV shall ignore, in spite of the fact they are set.
