About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Use standard Windows keyboard shortcuts to change font styles
It would be nice if you could change a selected font style by using the standard windows (MS office) shortcuts, such as CTRL-B for bold and CTRL-U for underline.  This would save many mouse clicks.
I realize that many people don't use Windows, so maybe it could be customized in the .ini file or would be dependent on what OS your are running.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
25 Comments
What about some kind of floating window, which is available in design mode only for the text being edited...
Like in WINWORD for example:
Example Gatekeeper
Status changed to: In Beta
DNatt, LV R&D
In Beta NXG or In Beta 2018?
Example Gatekeeper
LabVIEW 2018 beta.
DNatt, LV R&D
Example Gatekeeper
Status changed to: Completed
Available in LabVIEW 2018 and later. The Ctrl-B, Ctrl-I, and Ctrl-U shortcuts now bold, italicize, and underline text, respectively. This behavior only occurs while a text field is being edited. Otherwise, these keyboard shortcuts maintain their normal behavior.
DNatt, LV R&D
