This previously wasn't such a useful idea, because typically the datatypes unbundled would be different, requiring a To Variant to be able to get anywhere. This is still the only way I can see to do this (and unless I look into scripting, it's fairly time consuming):
Would it be possible to get either
a) a primitive node that takes an Enum and a Cluster as inputs, and outputs the data element matching the value of the enum as a variant (as in the code above). This can break at edit time if the enum contains any values which are not the labels of an element of the cluster, in a way similar to the case structure if the case is not covered by an enum value (but in reverse, I suppose. So then more like not having all values or default...).
b) far more excitingly (but I don't see how it would be possible) a VIM that outputs the data value without the variant. I can't quite see this being possible, since the value of an enum requires runtime information whilst the datatype output needs to be available at edit time, but I'll list it as a tentative dream.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
