User | Kudos |
6 | |
3 | |
3 | |
2 | |
2 |
When handling data in a Variant, I'm always interested in knowing the exact type of the data within the variant. In my own code I could add an attribute with the information, but when getting the value of a control that is not possible.
The problem is the automatic conversion done by the Variant To Data function. If the data is a double and the type parameter is set to an integer type, the double value is converted without any error.
My suggestion is to add a boolean parameter to the Variant To Data function to force it to return an error if the type parameter is not exactly the same as the data type.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
