取消
显示结果
搜索替代
您的意思是:
Daklu
Sticky context menu
状态: Declined
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
Labview implements lots of functionality in the right click menu, resulting in large and deep menu hierarchies.  Often I want to select multiple items, but the context menu disappears after a single selection requiring me to go back to the original item and renavigate the menu tree.  That's a lot of repetitive, fairly precise mousing.
I'd like to have a hot key that prevents the context menu from disappearing after I select an item.  For example, if I held down the Ctl key while deselecting "Label," I could immediately move down to "Caption" and select it, making the whole process much easier.
4 条评论
RoyA
How about if the menu stays open until a SECOND right-click.  So, right-click to open, change as many items as you want, right-click in EMPTY area of menu (or off of menu) to close.
jtagg
Waiting for a second right-click is then tedious for one-change access to the menu. We could try something more like this:
- right-click to open menu
- left-click on menu item does the usual, that is executes and closes menu
- right-click on menu item executes, but does not close the menu
This way nothing changes for simple case, but for those who want, there is the possibility. I don't know if this is better than using the ctrl key for example but it's important to not make the normal case more difficult to help the edge case.
Daklu
jtagg, I think that's a great way to implement the functionality.
Darren
Proven Zealot
状态已更改为: Declined
