I would like to be able to make static event registrations for an element that is contained within an array. Note: this is not just a registration of an event that happens to the array, but an event that happens to an element in the array.
This can currently be achieved with dynamic event registration, but I would like static event registration for two reasons: less code, and dynamic event registration must occur with a FP showing whereas static event registration never errors (meaning dynamic events can pose a problem for plug-in architectures using SubPanels).
Here's one specific example achieved with the current method of dynamic event registration. I have an array of a cluster that has two elements, but I only want to know when a user clicks on the Boolean.
I want to be able to statically register that same event, which would look something like this (in 8.6.1):
As a bonus, as part of the event data cluster on the left-hand side of the event structure, I would like an I32 array called "Index" that gives the multi-dimensional index of the item clicked.
只有注册用户才能在此添加评论。 如果您已经注册,请登录。 如果您还没有注册,请注册并登录。
