User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
I'm a huge fan of the Stall Data Flow malleable VI except in the case that I have it wired on an error wire (my most common use case) and there's an error on the wire. I generally trust and expect that VIs (especially those on the palettes) will no-op (with rare exceptions like close ref methods) and fail fast in the event of an error on the error in terminal. I understand that this is kind of a unique case since the VI in question is malleable and doesn't have an actual error in terminal, but my guess is that most users:
1. Wire this specific VIM on error wires most often
2. Likely don't want the VI to stall in the event of an error
3. Would prefer to see that error propagated as quickly as possible like most other VIs do
Thoughts?
