| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
When building Installers for an updated version of an executable, you can't select whether or not to overwrite the current source files directory. The reason this is a problem is when distributing to computers that need different configuration files that are installed with the original version but have since been customized to the specific computer. If you try to only include certain source files and not others then it still overwrites the entire directory and you lose the files you were trying to save. If there was an option in the Source File Settings window to "Overwrite", it could be automatically checked for the same default functionality but you could uncheck it to allow writing into existing directories.
If you like this idea then give me some Kudos and hopefully we can get it in the next version of LabVIEW!
Peter W.
Applications Engineering
