When you have to work with multiple LabVIEW projects at the same time, you may point to a VI of the second project, or save a VI in the other project ... This occurs frequently when you have to work with a project template which you have to duplicate !
The problem is that your project works fine ! But you point on misplaced VI's !
The problem will only be seen when you have to give the project to someone else, or 2 or 3 year after the project completion, when you want to made some updates. And then AIE ! A VI is missing !
It should be nice to generate an "Optional" warning (Popup), when any user action (save, insert VI on front panel ... ) handles with a VI not located under the project path.
This visual warning could be interresting to avoid this kind of error.
Manu.net
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
