User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
LabVIEW functions "Set Waveform Attribute" and "Get Waveform Attribute" could write/read any attribute name/value to waveform. But, according to help files (http://zone.ni.com/reference/en-XX/help/371361N-01/lvwave/set_waveform_attribute/), there are default attributes such as device number, channel name, etc., which could be set by NI-DAQ, and Express VIs. But sometimes there is need to set them manually (for example, while reading data from FPGA and building waveform from it).
It would be handy to include to Waveform pallete simple API with polymorphic VI to set and get those default attributes. Then one should not remember what exact name it has, but just take the function, select which attribute he needs, and use it.
Sincerely, kosist90.
