AB@17
Search Array and Count of Elements
Status: New
It would be good to have Search an Array and give the number of times the search element is available in the array.
Most of us have made this logic with for loop with an increment if it matches
AB
Kudos are Accepted
13 Comments
altenbach
Knight of NI
To create the count OR to create the array of indices, each element needs to be inspected one way or another, the array just needs another allocation, but we already know the worst case upper size limit. The count is not that inexpensive, IMHO. In one of your versions above, you are creating a full-size allocations for the boolean array, just to throw it away nanoseconds later and you are visiting each element of big arrays twice, first to create the boolean array and then again in the FOR loop.
Of course we don't know what the compiler does in the final machine code. 😉 Any "count" output would need to be smart enough not to generate any code unless the output is actually wired. Imagine we use "search array" in a loop and with each iteration the count is also generated. This would turn into ~O(N²). Not very cheap.
I still feel that "search array" should not be burdened with another output
wiebe@CARYA
Knight of NI
The point is that that is removed by the compiler when it's not used.
I do know that, as the timing exactly matches the version where it isn't there at all.
wiebe@CARYA
Knight of NI
I agree.
We're now looking for a .vim that does the trick (the best).
