When I use LabVIEW array control/indicator, I often come to such a need that I want go through all the array elements quickly, e.g., look for a specific value, maybe compare with each other, or examine if there is anything abnormal about the data, especically during logging/debugging.
I find there is no easy way to do it right now. I can enter the index so the display can quickly starts with that element. But how many times should I update the index to finish reviewing all the data? And how much should I add to the index to refresh with the next chunk of elements? Of course I can always resize the array to a new height, to accomodate more visible elements. But what's the proper size, and it's not good to drag an array control so long.
I know, I can e.g., save all data to file, plot them on chart, to view all data. But I don't think it worths the effort. Maybe all I want to do is to browse a block of neighouring data, probably not all of them.
It'd be terrific if mouse wheel is supported. When the mouse is focused on array control/indicator, wheel can control scroll up/down array elements. Even better, pressing "PgUp", "PgDn" can scroll a whole page(the height of array) up and down, respectively.
The mouse scroll wheel works to scroll any control that has a visible scrollbar.
