User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
Reporting labview bugs is too complicated.
I suggest that a "Report bug" item is added to the Help drop-down menu in the programming environment.
I know that when I'm coding and I'm short on time I always work around the bugs I find, never reporting them because I don't have the time for it.
A built in report feature where you can write an error description and an ENUM with the following entries:
No added info
Add screenshot of code
Add current VI
Add entire project
A category ENUM might also be appropriate.
Evaluation of the reports, etc. 'Best bug report of the month" could be posted on the startup screen news to further increase the use of the tool.
The error that made me post this is the following (it's so small that I'd never report it in the current setup):
Start Crtl-Left mouse dragging in a structure to expand it out into an area where block diagram free label arrows are pointing to nodes on the structure. This will break the arrows making them point at nothing (or rather the inside of the expanded structure instead of the nodes). It isn't auto fixed unless you double click the arrows and persists through reloading.
If this feature already exists... then it's too hard to find (at least for me)
