| User | Kudos |
| 13 | |
| 12 | |
| 9 | |
| 5 | |
| 4 |
I'd like to work with relative paths at a higher level of abstraction.
I often use path constants in block diagrams, and almost always I need relative paths. I love Browse for Path option on the file path constant. Inconveniently, I end up with an absolute path when I browse like that, then have to manually select the front end of the path, and drop a few other nodes and wires to specify what the path is relative to. The resulting code looks like this:
Four Relative Paths LabVIEW 2019
Note that the path 3 and path 4 are identical.
I would like to see a single node that:
Here is what the code displayed above would simplify to:
Four Relative Paths with New Node
I'd like the base path selection to include options consistent with those from the file palette. One way to do this is to have a shallow hierarchy like this:
This idea is based on the discussion from the Path Constants Relative to the Current VI's Directory Path idea. I'd like to thank AristosQueue and crossrulz for their feedback on that thread.
