Thanks for posting AQ. You can see from the history of the discussion forum that I was one of the first to post, and after discussing the above with NI (Th Sa), LAVA and JKI, I decided to make this a request on the Idea Exchange forum. I also have the upgrade, as I also posted about this problem as well.
I was able to create a successful workaround and made a OGPB package that installs the icons via install scripts, as the default directory is not supported in VIPM nor OGPB.
It would still be cool (and easier) if there was a public folder that was not User/OS dependent - maybe under the LabVIEW directory structure??
