TurboPhil
Provide a malleable "Traverse For G Objects" function
Status: New
We've all probably found ourselves writing various forms of this:
It would be great if there was a malleable version of the "Traverse For G Objects" function that shipped with LabVIEW to save a few headaches. Rather than passing in a string for the class name, and then adding a downstream ToMoreSpecific operation, it could accept the refnum constant (in the above example, the "Control" class ref) and return an array already cast to that class.
4 Comments
crossrulz
Knight of NI
Could not give this a kudos fast enough!
TurboPhil
I tried making a malleable of this myself, but ran into issues:
It turns out, you can't get the ClassName from a refnum constant (the constant is not a *valid* reference). You *could* still require passing in the class name along with the class itself, but that feels lame.
wiebe@CARYA
Knight of NI
You can use Get Refnum Information.vi on the reference control.
Get Refnum Information.vi returns an "VI Server generic type" enum. There seems to be a 1-1 mapping between classname and the enum value.
One could probably script something to change a class constant to all possible classes, run Get Refnum Information.vi on each value, to get the enum value...
raphschru
