DanyAllard
Provide a growable merge errors
Status: Completed
Available in NI LabVIEW 2010
Provide a growable merge errors.
Replace This:
By This:
Note : I have already done this with XNODE. But since XNODE are not available, I can't use it in my project.
LabVIEW ChampionArchitect
10 Comments
DanyAllard
An other note: My work was inspired by the work of Adam Rofer that create the first Merge Error with the old style xnode
JackDunaway
Trusted Enthusiast
Excellent idea, and nice graphic! It's all about a cleaner BD.
altenbach
Knight of NI
Just to clarify, the second image should also accept arrays of errors on any of the inputs. (similar to e.g. built array).
Maybe this idea could be combined with the following:
Boolean function accept Error Cluster
How about if boolean function would accept error clusters, we could simply use the compound arithmetic node (mode="or") to merge errors. Then we should be able to do an output configuration where we can select between boolean output and error cluster output.  The output would be the boolean OR of all error conditions and the rest of the outputs in the error cluster would be the first error if we select error output.
Robert_Hoffman
I agree with altenbach, I like the idea of the compound arithmetic node allowing error cluster inputs.  That would help clean up the error handling quite a bit.
muks
Proven Zealot
Simple, Effective and a nice one. How did I not see this
manu.NET
The idea is good, but i only have a remark about the name of the VI ...
The VI is called "Merge error" ... but this is not what the VI does !
In fact the VI select the first error found among the input terminals !
So I think that a name of "Get First Error" would be more appropriate !
Manu.
Manu.net
Wonger
NI Employee (retired)
Status changed to: In Development
DanyAllard
Good Thank you
Wonger
Status changed to: In Beta
Laura F.
Status changed to: Completed
