Falk_Wurster
Project explorer Dependencies -> Add file via context menu
Status: Declined
New Context menu command in project explorer
Right Click on any file in project explorer dependencies -> Add file to project
Vikings Software GmbH - software development excellence
5 Comments
crossrulz
Knight of NI
current workaround: you can hold Ctrl and select many files and then drag them into a virtual folder or target.
Falk_Wurster
If there are several 100 dependencies and you want to add just one special file, it's very bad to drag this file to project
alex_bauer
I was just about to make the same proposal.
If you ever tried to add one or more dependencies from vi.lib, you know why. Sometimes the files are located hundrets of entries below the project folder and the scrollbar seems to be never ending. Especially if you have installed several tool packages
Jeff-P
NI Employee (retired)
Status changed to: Declined
Falk_Wurster
Why is this Idea declined - it's not solved yet or? in newer LV Versions the drag and drop also more painfull
