current workaround: you can hold Ctrl and select many files and then drag them into a virtual folder or target.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
If you ever tried to add one or more dependencies from vi.lib, you know why. Sometimes the files are located hundrets of entries below the project folder and the scrollbar seems to be never ending. Especially if you have installed several tool packages
