| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
It would be helpful if I could programtically retrive the compile/build date of an EXE created with the LabVIEW through a property (maybe invoke?) node. Of course, this would be meaningless during development...Even if it is not an option to retrive this programatically with a property node, perhaps it can be something set when the EXE is built and retrived/displayed when the EXE runs?
I use the date the application is built in an indiacator onscreen with the revision number of the software to indicate revision and build date. Right now I have to manually change this everytime. I don't believe retriving the "modified date" the "File/Directory Info.vi" is safe enough as those file parameters can change.
I haven't been able to find a way to automate this, so I'm suggesting it here. Obviouslly, whenever I am doing something manually over and over again that is a good thing to automate.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
