| User | Kudos |
| 2 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
A programmatic eevent can be generated using val(signal). The problem is that every time val(signal) is called it generates an event, (even when it is a non [false] event). Just like keyboard events that only occur when a key is pressed (and/or released), can val(signal) be modified to respond in the same way. In other words, if val(signal) is given the value "False", it should not generate an event, only generating an event when val(signal) is "True". This would make code writing so much easier and stop the possiblity of potential race conditions.
