| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
When you have a probe to se the data in an array, you se all elements in one row (in the Value column) and just one element in the Probe Display area. If you have a large array, it is difficult to get a good overview.
My suggestion is that in the part of the probe window called Probe Display, you should be able to pull the bottom right corner and see several elements simultaneously.
An extra feature would be to also show the array size anywhere in the probe window.
Available in LabVIEW 2015 and later. When you resize the probe window with an array, the array display is resized to show more elements.
