EMAHJ
Possibility to change code when you are running in Suspend When Called mode
Status: Declined
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
It would be great to have possibility to change/edit the code when a VI is running in "Suspend when called mode".
I mean when the VI is "paused" and waiting for you to press the "run" button, right there, possibility to edit the code for that VI and run it ones, change a little bit and run it again and again...
I know that this means a lot for the NI developer team to solve..Smiley Wink
But what a functionality when you are into fault finding and testing out of new developed code! ! !
1 Comment
Darren
Proven Zealot
Status changed to: Declined
