PPLLC
PDF Generation from MS Office Products in Report Generator Toolkit
Status: New
If NI were to make the following modification to the Word_Save_Document vi, we would be able to generate PDF documents directly out of the Report Generation Toolkit. This may only be applicable to later versions of Word.
What is required is to handle the PDF file extension and set the appropriate wdSaveFormat value for the SaveAs Method. It would also be nice to be able control the show PDF after generation option, but just being able to save as PDF would be very useful.
VI modification
Chris
Practical Physics, LLC
www.practicalphysicsllc.com
6 Comments
Jokelnice
Yes, it would be a good idea.
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
crossrulz
Knight of NI
Jokelnice, if you like the idea so much give it a Kudos.  I've seen several posts by you saying you like the ideas but you don't give Kudos.  NI looks at the Kudos first.  So if you like the idea, give the Kudos.
Jokelnice
Ok, thanks
David_L
While not exactly what you requested, there are a few PDF generation tools on the LabVIEW Tools Network which might help in your application.
Custom PDF Generator for LabVIEW - Simplicity AI
PDF Toolkit for LabVIEW - Carya Automatisering
David_L
Also, it looks like there was already an idea posted a few years ago that is similar to this one:
Generating PDF protocolls with the Report Generation Toolkit
eamante
Kudos it!!!
