User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
Why does the block diagram span 1000's of pixels. I would like to allow a block diagram size maximum to be specified on a vi basis. This way I could set my vi to limit the block diagram from 0,0 to 1200,800 for example. This not only forces good style but also prevents the inadvertent placing of functions off the screen (have you ever dropped a functional global call by mistake off the field of view by mistake and tried to debug the vi?). This feature would be optional so use it if you like (or impose it on your new programmers). If set on an existing vi, the code would be moved into the field of view with a warning message if position coerrsion is needed.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
