User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
The idea is the same as Separate Compiled Code From Source File. When using external source code control (SCC) software like git, the user may want to track only the source code content changes. However, when every time saving the VI, the VI Revision History will be incremented. This reflects the change in VI attribute / VI properties, even though the other contents are the same.
This makes the commit log like git hard to trace the real change in the source code content from a high level. When using the compare VI tool, this attribute change will be one of the highlighted difference, which is quite distracting & confusing such as below:
I suggest this option can be disabled at the level of VI, project, or environment like the option of Seperate Compiled Code from VI. Hope it would be accepted 🙂
