The current error-case only allows two states, when the error-cluster is wired: "No error" or "Error".
My suggestion is, to allow any number of cases which depends on manually defined error-codes (see attached picture). The error-case must be enhanced so that error codes can be treated separately in individial cases.
Previously to handle a specific error code, first the code must be read from the error cluster and than be wired to the case. This is to be omitted.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Error-Case-Structure-to-Handel-Specific-Error-Nu...
