User | Kudos |
3 | |
3 | |
2 | |
2 | |
2 |
When running source code and you want to debug, you cannot get to the block diagram if it was not already open before running the program and you do not have the standard menu bar. This seems to be more of an issue with large programs where I have many screens. I'll be testing the software and find a problem deep into the program, but to get to the code I have to exit back to the main screen, stop the program, find the sub-vi with the bug, open it's block diagram, and then go back and re-run the program from the start to re-create the problem and start diagnosing. It would be a big time saver for me if the Ctrl+E shortcut during worked during run-time on screens where I'm not using the standard menu bar.
