DanyAllard
Be always able to open block diagram
Be able to open the block diagram with a hot key or right click menu even when you use custom menu on user interface. This option should be available for debugging in development environment and when debugging an executable with debugging enabled.
LabVIEW ChampionArchitect
5 Comments
Broken_Arrow
Possibly an option: Block Diagram Always Veiwable.
Richard
LabBEAN
Also, give Kudos to this duplicate idea (which came later, but happens to have more Kudos).
And, check this related idea out, too
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Darren
Proven Zealot
Status changed to: Duplicate
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Be-always-able-to-open-block-diagram/idi-p/917601 . Even though the other idea is slightly more recent, it has more kudos, so please go kudo that idea if you have not already.
Darren
Proven Zealot
Argh, sorry, included the wrong link in my 'closed as duplicate' message. Here is the correct link: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Opens-block-diagram-with-Ctrl-E-code-is-running-and-cu...
acordero0710
NI Employee (retired)
