User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
If code is running and one happens to leave a modal VI open, or opens a modal VI in the middle of a running piece of code, then the LabVIEW environment freezes-up and dis-allows any interaction with the code. It will be great to have a set of Key Strokes to re-set the code if this happens. The only way that I know of now is to hit [ALT + CTL + DEL] and killing the LabVIEW process. This ends up loosing unsaved work and requires a restart of LabVIEW.
Regards
Anthony L.
