SpaghettiCoder
Make creating subclasses less painfull
Status: New
Currently, new sublasses require the user to find the correct parent class in the class tree. In larger projects, this can be really painfull.
I suggest two simple things to improve this very common task:
1. Make the class tree searchable: Put a filter string input above where you can filter the tree by name
2. Add a "Create New Sub-Class from this Class" Item to the context menu in project explorer. This could simpy open the class tree with the matching class already selected. Something like this would also be great for interfaces.
2 Comments
crossrulz
Knight of NI
The search filter is covered in this idea: Filter/Search for Parent Class Selection
_carl
It's a duplicate, but you're getting by vote for visibility -- because the filter portion of this would make a huge improvement in my daily life. I have to sift through 100's of classes every time I go to create a new one, and it's a dreadful, time-consuming process.
