| User | Kudos |
| 14 | |
| 13 | |
| 9 | |
| 4 | |
| 3 |
what does the community think about configurable automatic type conversion between .NET and LabVIEW? We need to deal with a .NET API for a sensor which handles system time with nanoseconds since the 16th century. Don't know why they're doing this stuff.
To set the appropriate time you have to substract two .NET DateTimes. Everybody will know this will look like in LabVIEW.
You will have to use a method of the object to substract this. Now you're using DateTime.Substract. This means in LabVIEW.
Here it would be nice to have a checkable item in the right-click run-time menu for the invoke / property node to select or deselect the automatic type conversion so that the Substract() method would accept a DateTime class and not a LabVIEW timestamp.
Hope the idea is clear enough. I've checked the idea forum for this entry but didn't found it. If so, don't shoot me for a double post.
Tyler.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
