matt.baker
Make LabVIEW DPI aware to support high DPI screens and Windows scaling - Non blurry text and graphics
Status: New
The LabVIEW UX is poor when using high DPI screens. I would agree that Windows is partly to blame initially, but there are newer design guidelines that solve this and they have been around for >3 years. The application should be DPI aware and act accordingly. For a > £4000 piece of software I expect more...
All of the text and graphics are blurry when it should be sharp with no end-user way to correct this.
Non Windows mouse cursors are tiny.
Some of the blurry text and graphics highlighted in red. Notice how the title bar text and other Windows' applications are sharp.Some of the blurry text and graphics highlighted in red. Notice how the title bar text and other Windows' applications are sharp.
6 Comments
crossrulz
Knight of NI
This should be not an issue with NGX being vector based instead of bit map based graphics in classic LabVIEW.
Darren
Proven Zealot
Status changed to: Already Implemented
LabVIEW Classic will continue to be bitmap-based graphics, but the issue is solved with the vector-based graphics of LabVIEW NXG.
Petru_Tarabuta
Could this idea's status be reset to "New" please so that it can receive kudos?
Darren
Proven Zealot
Status changed to: New
Petru_Tarabuta
Thanks!
InfiniteNothing
To be a bit more precise with my ask, Windows offers a scaling option for high resolution displays. For example, you might want to scale by 200% so the text on your screen isn't tiny. LabVIEW now offers the ability to zoom out on your block diagram, so, for example, you could zoom out to 50%. Now, one would expect that the two settings would cancel each other out and you'd get your standard 100% bitmap graphics like other bitmap programs (e.g. GIMP) but instead you get this abomination
CLED (2016)
